Page 6 of 8
Posted: Tue Jul 30, 2019 5:39 pm
CORRECTION!
I was sent the wrong photo of the A-6 contest score sheet. Here are the correct results.
  1. Bill Watson 457.5 Seconds
  2. Will Woods 408.1
  3. Norm Furutani 391.3
  4. Paul Avery 340.6
  5. Jim Leuken 276.0
  6. Don Butman 224.5
  7. Pete Basone 175.8
Again, I wasn't at the contest. Sorry about the error.
Posted: Tue Aug 06, 2019 2:03 am
On Wednesday, July 31, the Dime Scale Contest (9 cent scale) was held in the Stonehurst gym. We had a great meeting before the contest which ended with a few surprised, "The contest is today?" remarks. As it turned out only three people brought dimers. But, following the FAC three contestants makes a contest rule it went ahead anyway.
Bill Watson brought a freshly made Heath Parasol. Joe Whiting brought a SIPA S.11 (French Arado 96) and a Fokker DXVII. Don Butman brought his SB2C-3 and a Howard DGA-15. Once Bill got the Heath trimmed it was evident that he would win the contest. Joe's Fokker had been finished the night before the contest and was in need of more trimming that could be done that morning so he flew the reliable SIPA S.11. Don's SB2C-3 was beautifully stable in flight but he couldn't get over 30 seconds out of it so he switched to the DGA-15. (Although he held the more colorful Curtiss for the photos.)
The contest was for the best single flight of unlimited (well, completed before the 11:30 cutoff time) attempts.
The results:
  • 1. Bill Watson 80.3 seconds
  • 2, Joe Whiting 52.41
  • 3. Don Butman 36.1
CD Joe Whiting, Timer Howard Littman
The next contest is the Rubber Payload Contest on August 14.
Posted: Fri Aug 16, 2019 3:23 am
RUBBER PAYLOAD CONTEST - AUGUST 14TH
If not the best attended OFFC contest it was certainly one of the most fun. Everyone agreed that we will have to do this one again. There were only two entries, Bill Watson and Jim Leuken. Now, that may not sound like much of a contest but everyone there was fascinated and many more will participate the next time. Bill and Jim took two different approaches to the problem.
Bill took the high camber airfoil approach. His model was sturdy but only weighed 10 grams and had a low wing design reminiscent of a 1930s ROG model. He installed a small keel, under the wing, to attach the clay payload, keeping the CG centered. His motor was 1/8” flat, tan rubber, as required by the rules, and the final motor weighed 2.4 grams. The last flight lifted 25.6 grams of clay.
Jim’s approach was a high winged, contemporary ROG type model with a pylon, tip dihedral and an airfoil with a very small camber. He wrapped the clay load around the pylon to maintain the CG position. His last flight, with essentially the same motor as Bill’s model lifted 25.3 grams of clay and might have lifted more except he ran out of time.
This contest was more closely fought than would appear with only two contestants. The biggest problem was getting the heavily laden models to turn inside the gym. There were many flights that did not lift off and became high speed taxi runs. Several flights did not make the 20 second minimum (leading to an observation that ’20 seconds can be a long time’). And, of course many flights ended against the wall. Hitting the ceiling was not an issue here.
This contest was a successful experiment and it was agreed that the next time there will be many more contestants.
The next contest is Comet Phantom Flash, plan stock except for thrust button, prop shaft and prop, on August 28th.
Posted: Fri Sep 27, 2019 10:12 pm
The contest for August was Phantom Flash. Embarrassingly enough, your editor didn’t get to the contest until the very end. And, not knowing how long my prior commitment would take, I didn’t bring my model. Neither did a lot of other people and the contest was between our usual three stalwarts, Bill Watson, Jim Lieuken and Don Butman. They finished in that order.
I took a picture of the score sheet and a picture of the group at the end. However, when I got home I could not find those pictures on my phone, so I don’t have the detail times or the group picture. Mia Culpa!
The next O.F.F.C contest is the One Design the design in question being the Mini Sonic. A dozen members bought kits and we will see how many are flown in the contest. Incentive to finish and fly is added because the contest is a do-back. It was to be held on Wednesday, September 26 but was postponed to Wednesday, October 2 due to floor work in the gym.
Posted: Fri Oct 11, 2019 6:45 pm
The One Design contest, for Mini-Sonics, went off, as scheduled, on September 25. There was a good turnout with nine entrants out of the twelve kits sold. (I could not find my model! It's in my shop somewhere.) The nine entrants got their dough back.
The contestants, flying what is essentially an outdoor model indoors, still achieved remarkably good times with seven of the nine models posting times over one minute. The contest was decided on the best flight of unlimited trys so there were few moments when there were no models in the air.
1. Pete Basone 83.7 seconds
2. Don Butman 80.7
3. Joe Whiting 79.5
4. Bill Watson 74.5
5. Don Smith 66.8
6. Jim Leuken 64.8
7. Bill Blanchard 62.9
8. Wade Wiley 44.0
9. Wynn Hammer 11.6
CD(s) Bill Watson, Dave Gee
The next contest will be on October 30, for No-Cal models. Don Butman, wizard of No-Cals, is the CD and he has come up with an interesting set of rules including ROG from, rolling wheels, required. Since the annual Pearl Harbor No-Cal contest will be the next week there are many Pearl Harbor eligible models being tested with landing gear.
Posted: Tue Oct 15, 2019 5:29 pm
The NoCal contest gets more interesting. Rules specify a 16 inch span (Legal) NoCal model but with a 12 gram minimum weight. Fixed landing gear with rolling wheels required, no drop off gear, and all flights must start ROG.
Posted: Thu Nov 07, 2019 12:00 am
The O.F.F.C. NoCal contest for 2019 happened on October 30. Unfortunately, there were a few astonished, "The contest is today?" remarks at the meeting and there were only 4 entries. The four of us that did fly had a lot of fun.
Now. Pete Basone and I were trimming models we expect to fly in the Pearl Harbor NoCal contest in December so he had a Zero and I had a Brewster Buffalo. Bill Watson, for some reason, probably because it was appropriate to the Black Sheep Squadron, and the model would be displayed at the AMA EXPO the following weekend built a Corsair. Don Butman, the CD for the event, brought a high winged Farman with a big barn door of a wing. With the 12 gram minimum weight and all the fighters flying gear down you could easily predict the winner.
The contest was for the total of the best two flights out of five attempts.
  1. Don Butman Farman 13 grams 159 seconds
  2. Bill Watson Corsair 12 grams 134.7
  3. Howard Littman Buffalo 12 grams 77.8
  4. Pete Basone Zero 14 grams 52.4
Winn Hammer brought his Zipper, not really legitimate since it is a model of a model, but he couldn't get it flying well enough to compete.
The November 27 contest will be a one design, P-18 Hawk, with a stock North Pacific front end. (Yes, we have a supply of them.)
Posted: Sat Nov 30, 2019 5:18 am
The November 27th P-18 contest was rescheduled to December 4th. This was due to the weather being so bad that it would have been dangerous for many members to drive to the meeting!
December becomes a very busy contest month with the P-18 contest on the 4th, the Black Sheep Squadron's Pearl Harbor NoCal contest on the 6th and the ROG Unlimited contest on the 18. This last because there will be no meeting on the 25th.
Posted: Sat Nov 30, 2019 5:53 am
Correction! The Pearl Harbor NoCal contest is on the 13th.
Posted: Tue Dec 10, 2019 6:52 pm
I didn't witness the P-18 contest because I had to leave right after the meeting but do have the results.
So, without the usual drama, the results were:
  1. Pete Basone 209 seconds
  2. DonButman 195
  3. Will Woods 194
  4. Bill Watson 187
  5. Don Smith 175
Don Butman's other P-18 flew 185 seconds.
The next contest is the Ed Slobad Memorial ROG Unlimited, open to any rubber powered model that can ROG, next Wednesday. Here you can find anything such as Penny Planes with landing gear. Fun!
